Trouble finding B5 S4 gear ratios and final drive ratio. NE1 know off top of their head?
#17
AudiWorld Uber User
"Converter lockup engages even in first gear
Like its predecessor, the new seven-speed automatic transmission is equipped with a torque converter lockup clutch. Under a wide range of operating conditions the lockup clutch, located in the hydrodynamic torque converter, almost completely eliminates slip between the pump and turbine. Whenever appropriate, it creates a virtually rigid connection between the engine and the transmission shaft, thus preventing power losses. On the new Mercedes-Benz 7G-TRONIC, converter lockup engages even in first gear, rather than only in the higher gears as on conventional automatic transmissions.
The lockup clutch engages with a degree of controlled slippage, which makes a further contribution to smoothness."
clarkh
9
07-22-2003 04:31 AM
EricK
9
07-09-2001 04:55 AM
SnoStr
11-25-2000 07:54 AM
