Trouble with my 00' S4 (CODES)
Old 08-17-2008, 03:14 PM
S4incter's Avatar
Default Trouble with my 00' S4 (CODES)
I've had a ABS light with blinking brake light and an AIRBAG light on for the past few months. These will be fixed soon as I figure what is wrong. The problem that occured yesterday was EPC and CEL lights. Got:
17579 P1171 Throttle Actuation Potentiometer Sign.2 Range/Performance
18014 P1606 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
Do you think this is due to the ABS/BRAKE lights being on?
Thanks again, all help is greatly appreciated!
Old 08-17-2008, 03:22 PM
BrokenRocket's Avatar
Replace the ABS Module
Old 08-17-2008, 03:44 PM
S4incter's Avatar
Default Re: Replace the ABS Module
K, I figured that would be in the near future. Do you think that is the problem causeing the CEL codes and EPC light?
Old 08-17-2008, 03:46 PM
It will cause the ABS light and a blinking Brake light... not sure about the EPC light though.
Old 08-17-2008, 06:47 PM
sidespar's Avatar
Default I can repair the module for you waaaay cheaper than a new one costs
email me if you are interested:
sidespar at yahoo dotcom
Old 08-17-2008, 07:07 PM
S4incter's Avatar
Default Re: I can repair the module for you waaaay cheaper than a new one costs
funny, i sent you an email earlier, thanks.
Old 08-17-2008, 07:14 PM
S4incter's Avatar
I ordered my vag com from ross tech today and am going to try to communicate with it so i'll let you know the results
Old 08-17-2008, 10:03 PM
FatFreeVW's Avatar
Default Clear the ABS Controller's codes using a vag-com.
even if you clear the CEL, the code will still be present in the abs controller.
Old 08-18-2008, 04:24 PM
S4incter's Avatar
Default Used my vag-com today, couldn't communicate with the abs module...
so i'm figuring the module is what is the problem?
Old 08-20-2008, 05:42 AM
sidespar's Avatar
yes sounds like it, send it to me if you want a rebuild cheaper than module masters.
CTMechE
08-13-2009 11:27 AM
NewAudiGuy
06-06-2008 07:48 PM
carfan87
10-27-2005 07:23 PM
A4 C
04-21-2004 10:42 AM
JasonS4+Festicle
02-21-2004 06:47 PM
Quick Reply: Trouble with my 00' S4 (CODES)
