Troubleshooting help. Low boost after changing spark plugs. Logs inside.
Well, the story is I replaced my spark plugs with new Bosch Platins (I was already running the same plugs for 40k prior to this). After I replaced the plugs I noticed that I wasn't getting full boost. My car usually peaks at about 17-18 psi and holds it there. Now I'm getting about 13 psi upon going WOT and then it slowly builds to 15 psi.
To me it seems like a simple boost leak somewhere but I did some logging to see if it could be anything else. First I checked for misfires to see if maybe one of the plugs were bad. No misfires at all. So then I logged Boost, timing, MAF, and O2 voltage (I've been getting intermittent CELs with "warm up catalyst" code).
Here are the charts:
<img src="http://home.hawaii.rr.com/his4/Boost_log_073107.jpg">
<img src="http://home.hawaii.rr.com/his4/Timing_log_073107.jpg">
<img src="http://home.hawaii.rr.com/his4/MAF_log_073107.jpg">
<img src="http://home.hawaii.rr.com/his4/O2_log_073107.jpg">
For the O2 logs I wasn't sure which sensor was which since they are not labeled in the log file but that's the order which they were arranged in the .csv file.
I haven't done a pressure test yet but that was my next step. Does anyone see anything other than a simple boost leak somewhere? BTW, these are all third gear runs.
I discovered that my TBB was torn so I replaced that. Before replacing the TBB I wasn't getting more than 12 psi so it has gotten better but not to where it was before. This is why I suspect it's just another boost leak somewhere.
If it was because of the battery, I would think the car should have recovered by now. I also changed the battery last week but shouldn't play a part in this either.
Not right away but it comes back after a few weeks. I don't believe the CEL and the low boost issue are related. I think replacing the secondary O2 sensors will probably solve the CEL problem. I just have to get under the car and see how easy it is to get to them to see if I can actually do it myself.
In all honesty, if it does come to the point of blown turbos, I'll probably be looking at another car. Maybe a new S4 or a BMW 535i.
Pete5587
11
11-02-2008 06:38 PM
Gotpancit
9
08-02-2007 11:59 AM
HIS4
04-16-2007 05:51 PM
French-Fried-Rings
13
12-11-2006 04:18 PM
Utah01S4
22
02-22-2006 05:45 AM
