trying to get a handle on fuel delivery and duty cycles. little help
here is the thread where my train of thought originated.
basically what duty cycle is ok and whats the function of the ecu reading it. where does efficiency start to deplete?<ul><li><a href="https://forums.audiworld.com/s4/msgs/2186118.phtml">orig thread</a></li></ul>
If your a/f looks good and you aren't knocking...
Then why are you worried? The fuel is obviously there, otherwise you would be knocking like crazy.
Obviously, a DC above 100% is concerning, but if you aren't leaning out and you aren't knocking, then you have plenty of fuel. Trust me, you know when you run out of injector.
For bigger snails? Scary stuff.
I would worry more about restrictions (fuel lines and rails) and fuel flow (big *** fuel pump) more than duty cycles.
I run 950's on my eclipse and it took a good amount of modification to the fuel system to even get it to flow that much fuel. Not so easy as changing out the injectors.
Duty cycles are pretty useless at that point. Tune with a wideband and knock. If your car leans out on the top end and your DC is really high, time to upsize.
Whitjr
17
06-02-2008 05:32 AM
JDMnAR
02-22-2008 10:53 AM
Popflyz13
12-17-2007 06:11 PM
HOPSBurner
Chicago Discussion
07-15-2005 01:53 PM
