Trying to help a friend with codes but have no idea could someone else help us out...TIA (more)
10 Faults Found:
01211 - Belt Tensioner Igniter: Rear Driver Side (N196)
32-10 - Resistance too High - Intermittent
01587 - Igniter 2 for Airbag: Drivers Side (N250)
00590 - Airbag Igniter 2: Passenger Side (N132)
01213 - Belt Tensioner Igniter: Rear Middle (N198)
36-10 - Open Circuit - Intermittent
01219 - Rear Airbag Igniter: Driver Side (N201)
01220 - Rear Airbag Igniter: Passenger Side (N202)
01578 - Airbag Deactivation Warning Lamp: Passenger Side (K145)
31-10 - Open or Short to Ground - Intermittent
01591 - Indicator Lamp for Airbag Off: Drivers Side (K144)
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00656 - Seat Occupied Sensor: Passenger Side (G128)
That seems to be your common denominator. Agree with S4-KGH...reset codes, and if they come back, find out where the control module is, and replace it.
sometimes the culprit is entirely obvious and easily fixed (a la ABS module and ignition amplifier failures). Other times it's not so easy...but it costs you nothing to look and see.
