update on the apr v5 allroad ecu in my H-box S4. also, DTC help needed
AudiWorld Expert
i just vagged it, and it's recoded to 8D h-box.
also, here are the dtc's i've logged since i had it (car still runs fine, no CEL, boost max spikes around 1.2bar. will run full logging soon when i get a chance and a bit of open road)
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
and one more old dtc i didn't clear:
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15208
Shop #: WSC 06435
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Coding: 15208
Shop #: WSC 06435
2 Faults Found:
35-00 - -
00956 - Key 2
18010 - Normal. From disconnecting the ECU or battery
18057 - The ECU is expecting a Tiptronic transmission. Guessing the allroad ECU was from a tiptronic?
16487 - You might have a bad MAF. What are your peak MAF values from Block 003?
16684-16686 - Car had some misfires. I'd clear the codes and see if these return.
17965 - Your car overboosted. If you have aftermarktet DVs, they could be sticking shut and not relieving pressure during shifts. Try regreasing them.
All of the codes are intermittent, so it would probably be a good idea to clear them and see which ones return.
-Dave Pramanik
-Dave Pramanik
AudiWorld Expert
until i get a clean wot run i wont really know
just tooling around town the maf values look ok.
i have stock DV's, probably getting 710n's soon anyway.
hhv011
08-19-2012 07:17 PM
Follow up, I've been running at 5lbs last week. pulled/cleared codes I've searched but have some q's
jwood_a4
03-15-2008 07:16 AM
BrokenRocket
02-02-2006 01:48 PM
s4florida
04-10-2005 08:04 AM
