Used the 24mm nut on the front of the Crankshaft to counterhold the
shaft while removing the Flywheel bolts. Pretty dumb thing in hindsight so now I want to double check that it didn't get loosened. Is the Crank Pin sufficient to lock & hold the Crank for that kind of loading? If it is, then I assume I'm OK to use the pin when reinstalling the Flywheel bolts right?
Thanks,
Tony
Thanks,
Tony
The crank bolt is torqued to a higher spec than the flywheel bolts, so counterholding it there for torquing the flywheel bolts isn't a problem.
was being **** and allowing for the additional moment-arm when wailing (sp?) on the off-centered Flywheel bolts. Makes up a little of the difference... "It's just so dam hard when it's your own car your working on :-)"
How do I even measure 200Nm anyway? My biggest T-Wrench goes to ~150Nm.
Thanks again.
Thanks again.
The flywheel only mounts in one orientation (the bolts pattern is not uniform). If the bolts are off-center, then the flywheel is not in the proper orientation.
mental check on how much Torque I applied to the Crank bolt through the undoing the F-Wheel bolts. Assuming they were tightened at 50Nm then you have to account for the fact they are "displaced" from the axis of the crank by 30-40mm which until they budge, adds to the moment arm and hence the torque applied to the crank nut. Still well under 200 though.
Tony
Tony
alki4000cs
10-29-2008 09:46 AM
2001s4loored
10
08-26-2008 05:04 PM
eigenvector
08-17-2006 05:28 AM
s4greg
08-13-2005 09:38 PM
Audi-Impaired
05-17-2002 05:37 AM
