Using stock fuel rail on RS4 manifold? Strange issue i've run into... help?
#11
Right side does not line up in these pics:
<img src="http://img247.imageshack.us/img247/3134/dsc1256yq9.jpg">
Right side is off:
<img src="http://img340.imageshack.us/img340/8914/dsc1257al5.jpg">
Left side lines up:
<img src="http://img206.imageshack.us/img206/9202/dsc1258nx2.jpg">
You can do this vice-versa but then the left side won't line up but the right side will.
Right side is off:
Left side lines up:
#12
seems like stock fuel rail is simply too wide? I think I would have to cut all the lines and shorten it by about a quarter inch and then braze the lines back together.<ul><li><a href="https://forums.audiworld.com/s4/msgs/2790038.phtml">https://forums.audiworld.com/s4/msgs/2790038.phtml</a</li></ul>
#14
heat the middle lines up and bend it very little.
an easy wahy would be to place some metal pipe on top of the intake manifold heat up the place where it touches and force it down while its hot.
#15
Wouldn't I need to heat the three tubes crossing over the manifold at the same time...to make the rail narrower?
#16
if you heat the 3 tubes, and bent the rail over a pipe carefully it should put some arc to the fuel rail, making it able to be lined up.
the key is no sharp bends to kink any lines.
#17
to the RS4 holes for the injector.
sigh...I think it's a lost cause.
#19
I think I might suck it up and get the RS4 rail. This is the exact reason I've been holding off on my injector purchase.
Jeff Vader - boscoj
05-14-2004 10:11 AM
wishbone
15
02-18-2004 11:08 AM
low rider
09-26-2003 12:11 PM
chuangs4
13
04-19-2003 06:42 PM
