uuc shifter
i have installed a uuc short shifter for my s4.i have try 20%and 30% reduction,but for both,i found it so hard to get into 2nd gear.is it the case for u guys,and what i have may done wrong?please help.<p>macats
Second is tricky. Loosen both the bolt to the shift linkage and the slide rail. Now, adjust the position of the shifter so that the first to second shift is easier, and neutral is with the shifter STRAIGHT UP AND CENTER. This should do the trick. Basically, you have to set up the shifter based on the first to second shift. As such, it turns out that fifth and sixth sit out a little far to the right from the other four gears, but it's no big deal, since most of your "sport driving" will involve mainly the lower four gears anyway.
lemond33
9
04-07-2006 09:53 PM
Kid
06-24-2001 01:25 PM
