VAG Codes
I don't really understand the codes but I got my car VAG'd to find out why the Traction Control (ESP), ABS and brake lights are on when I am driving. Maybe someone on this forum would have more insight and could assist me as to where and/or what needs to be fixed. Here are the main issue reported from the read out:
Control Module Part Number: 8D0 907 551 AA
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06751
Work Shop Code: WSC 63351
4 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Anybody have any ideas?
4 Faults Found:
P1423 - 35-00 - -
P1411 - 35-00 - -
2 Faults Found:
35-00 - -
Well when I did the search, I searched the VAG forum and the solution came up that he changed the MAF on the car and it fixed everything. The MAF is brand new on my car and it didn't seem like he new for sure what the problem was exactly, he just got lucky. I don't BS on forums.
CrazyINP-12V Ivan
01-18-2007 08:54 AM
Vtec_Killer
11
08-26-2003 08:50 AM
