Vag com Q: I scanned a DTC for the radio (65535) but when I brought it in to the dealer
for a service they said they don't detect any DTC's. Assuming the DTC is still there (I'll have to check again), is it possible for it to be VAG-detectable but not visible to the shop?
Thanks
Rory
DTC:
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 06435
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Thanks
Rory
DTC:
Address 56: Radio
Coding: 00110
Shop #: WSC 06435
1 Fault Found:
00-00 - -
One example-- I do a automated scan (whatever it's called) and I come up with a radio DTC, but then when I go to that specific block to check it out-- presto! It's gone-- without clearing it.
Then other times, it would show up, I'd clear it, and it would be back immediately. ???
There doesn't seem to be any operational problem, and again, since it's just the radio, I ignore it. Of course now it has been fine for the last few VAG sessions (~3 months).
If it happened with other blocks, I might assume I had a VAG-related hardware or software problem, but it's only the radio.
vincent9993
VAG-COM Discussion
05-18-2004 12:13 PM
