VAG Data - should I be concerned? I've already STFA btw...
<center><img src="http://pictureposter.audiworld.com/33465/vag_001.jpg"></center><p>This is my first time logging with a VAG (took this one on my way to work to try things out), so I'd appreciate any advice...kinda worried about the spike...
I have a GIAC-X version 8 (to the best of my knowledge). Recently had the MAF and a couple O2 sensors replaced.
Everything looks fine, the spike was probably during a shift..
Do you "Feel" anything wrong, because I don't see anything wrong, but again this chart tells us little
I take it you subtracted ambient pressure from the boost readings? Otherwise they should be around 1000 mbar off throttle and peak somewhere above 2000 mbar.
The MAF readings of 350g/sec are way too high for a chipped S4.
-Dave Pramanik
-Dave Pramanik
Correct, I subtracted the ambient temperature. As for the MAF readings, I may have taken that data from the calculated maf reading as opposed to sensor...should calculated be that high though?
Sloooo4esT
Audi Original "S" Cars
11-14-2007 08:36 AM
Damwatsyoname
09-21-2004 08:29 PM
AWDrivel
04-05-2004 09:38 AM
2low4snow
02-01-2004 02:23 PM
