VAG Dual MAF Block. For those that wanted to know and someone would not share
AudiWorld Expert
Not sure what the F$CK the attitude about not posting information is all about. Trying to sell it or something? Be the only one etc.. Whatever..
The block appears to be 211 on your VAG.
There are 2 MAF G/S readings and they definately show different values, maybe a good test to see if you have a dirty filter or something, who knows!
Tory
Tory
Who knew and didn't share? I read about it on the VAG-COM newsgroup. Didn't realize it was a big secret.
The first field is the actual MAF value and the second is the calculated expected MAF value (or I may have those backwards... not sure).
I did some testing on an A4 with a bad MAF and the difference between the two values was dramatic. Once the MAF was replaced, the values agreed to within a few percent.
-Dave Pramanik
-Dave Pramanik
AudiWorld Expert
I think the first is spec'd and the second actual. Well Since my numbers show the left column higher then the right (an assumption about which is spec'd vs actual)
115 and 120 are examples so I think your assumption is right. Only in the 50-56 blocks does actual RPM appear before specified RPM I think those blocks have to do with engine RPM compensation when the A/C compressor kicks on.
Thanks for the information, the blocks passed like 170 don't seem to be well documented, but I am trying to keep track best as I can.
<img src="http://pictureposter.audiworld.com/14154/vagdb.jpg">
yeah, you (gk1) got that online somewhere?
