VAG O2 Sensor Codes Help Please (Inside)
I had a passenger side turbo shaft fracture which obviously drenched everything downstream. I've read about using VW O2s, universals and OEMs, each with seeming confidence but with MAJOR price differences. I want to do the RIGHT thing though not necessarily the the most pricey way. Through research I have saved SO MUCH money on my other cars over the years. I have never seen O2s priced at $160 - $180 each before! My VAG below. Considerate, informed suggestions are appreciated!
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8D0 907 551 A
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06611
Work Shop Code: WSC 06325
6 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 35-00 - -
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
6 Faults Found:
P1118 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
P0431 - 35-00 - -
You probably toasted both with the turbo failure. That's what happened to mine...
although I only toasted S1. The cat probably saved S2. Oil everywhere. VAST is probably the best place to go for O2 replacements.
spoon2000
04-01-2011 01:26 PM
BlackS4tt (Josh)
10-18-2005 01:28 PM
BlackS4tt (Josh)
VAG-COM Discussion
09-01-2005 07:33 PM
justwentgerman212
10-17-2004 12:19 PM
