Which VAST fueling car trapped over 120mph,twincities or something like that?Whats his exact setup..
<center><img src="http://pictureposter.audiworld.com/99454/11sec_et_slip.jpg"></center><p>I am running this setup from Vast:
open element intake-ITG cone filter
85mm MAF
42# Delphi's
modified 4bar FPR (around 4.5bar)
Walbro pump
Giac X flashload
Lemmi settings:
-6%ish fueling (O2's were .89-.90 on that run)
+3 deg timing
100% accel, decel, secondary fuel
+50 rpm idle
+3 torque offset
I was running 100oct race fuel, but it was a 50/50 mix of 94oct and 100oct, so roughly about 96oct. That is my usual mix of gas. I never have enough time to get a true 100oct in the tank, it is always a mix. Can't wait until some cooler weather and I am going back to see if I can get even faster. I also need to play around with adding timing for the race gas. My CF's were just above zero on that run with timing @23deg at redline.
If you look at some of my prior posts, I detailed all of the other go-fast goodies.
Brian
85mm MAF
42# Delphi's
Walbro pump
Giac X flashload
Lemmi settings:
+3 deg timing
+50 rpm idle
+3 torque offset
Brian
Detroit
61
02-17-2009 02:56 PM
Catamount90
09-20-2006 03:00 PM
FATS experts: My timing has strange dips and spikes through the rpm range. They are magnified on ...
SLPR S4
06-29-2006 06:47 PM
Marin S4
21
12-09-2004 04:05 PM
QuickSilver2.0T
Performance and Tuning
11
09-18-2004 10:35 AM
