vibration at different speeds
on the highway I get vibration at varying speeds, at 60-80 its the worst (hardest vibration) at close to 100 there isnt much.
I also get some vibration when accelerating at medium speeds,
coudl this just be a wheel balance issue, or a driveline issue>?
Just put on new control arms, tie rod, motor mounts and had an alighment it drives perfectly straight, just vibration at different speeds,
what should I be looking for, coudl my u joints be bad in the driveline?
Get a hunter road force balance. This should identify any tire and wheel issues.
The site linked has a locator.
Regarding driveshaft/propshaft, has it ever been removed? I replaced mine due to the front CV going dry and starting to make a ticking noise at low speeds. The only reason it went dry is because when shops pull the trans, they don't properly repack the CV w/ grease AND replace the propshaft flange gasket. The rear CV on the propshaft was never disconnnected and was nice and tight even after 80K mi. (Poor workmanship sucks)<ul><li><a href="http://www.gsp9700.com/">http://www.gsp9700.com/</a></li></ul>
have them rebalance. Some have a "high performance" balance where they spin it faster and have tighter tolerances (so I'm told). FYI, Big O' Tires has improperly balanced TWO sets of wheels for me. I took it somewhere else and got it rebalanced and now no more vibrations. I find that vibrations are worst between 60-80.
clinton c
09-29-2008 08:41 PM
bl98263
09-09-2003 03:32 PM
