VSS is STILL throwing a code!
#15
The wire from the VSS to the cluster is brown/red. The wire from the cluster to pin 54 ECU is blue/lilac.
To test with the breakout box get a diode test list and connect to #3 and #54. Just turn ign on and spin the front left wheel by hand. There should be very brief flashes. If there are no flashes check for continuity between the cluster and pin 54.
