Want to test max boost...Have boost gauge...What gear and rpm should I try to reach?
and watch for max boost.
i'd be interested in knowing if you get minor spiking at WOT?
for example, sometimes when i go WOT in 2nd or higher i get a short instance where the gauge goes up to 17-20 psi then levels off around 14-15 psi about 1/2 second later. i don't know if this is gauge backlash since the boost builds so rapidly or if it's actual boost.
yes, i'm chipped.
yes, i'm chipped.
how much your car will spike. You can run to 6500 in 3rd and see what the boost levels off to....but I don't know if you want to try the pull in 6th to 6500....might be going a little fast there on the highway. :-p
