wastegate adjusted. logs logs logs
<img src="http://www.myfootsmells.com/s4/logs/wga/003-115-031.gif">
<img src="http://www.myfootsmells.com/s4/logs/wga/003-020-026.gif">
I'm running GIAC Stage 3- code w/ MBC. I can pretty much only play with boost. Suggestions?
Thanks.
Thanks.
isnt it way too rich? what fuel are you on? i was told with 91 craptan, the sweet spot is just south side of 0.89
It's pretty well laid out there since it is in excel format. Maybe if you clarify which part you're having difficulty reading, we can help you out.
Basically, it's ungodly slow and hella rich. Airflow seems like it might be low as well, although can't really be sure without a run all the way up.
