Water Injection testing/write up added to the tech section.
<ul><li><a href="https://www.audiworld.com/tech/eng80a.shtml">Water Injection Write Up</a></li></ul>
Aquamist specifying a location for the nozzles. I've gone through most of the discussions on their WI forum and they seem to lean toward testing to see what works best for each vehicle.
sprayed, it was around what I should have for a 10-15% water to fuel ratio. Since I've also upped the methanol percentage, I needed to increase the nozzle size. Aquamist recommends one nozzle size larger with a methanol mixture to offset the reduction in cooling that methanol has versus water. Once I get around to experimenting some more I'll try a pair of 0.5 nozzles and see if I can accomplish the same end result with less water.
