Waterford Hills PCA Driver's Education Event Write-Up.... (sorry, long)
#11
I absolutely love the PF-01's, haven't tried the Ferrodo's yet. I've heard ruminations about running the 01's and then trying to switch back to street pads on the same rotors being a bad idea, but I can't honestly verify that. Hence why I have two sets of rotors I guess. Talk to Matt at Stoptech. Both pads (and second set of rotors) are a bit expensive though, but I assure you you won't regret the purchase.
#12
In a nut shell, they are not confidence inspring when hot and being worked hard...sometimes have "gaps" in the pedal travel where it's not as firm and sometimes pedal travels very deep without ABS kicking in and/or a huge amount of braking occurring.
Over the winter, will definitely look into this. Either I'm blowing this out of proprtion or I'll stumble across whatever is causing this in the near future.
#14
Are you able to compare these to the PF-01s? I read the descriptions on Stoptech's site, but still could use some additional feeback. Thanks to Kaiserwilhelmi for the initial response and thanks to anyone who can answer this one.
#15
but maybe I'm just too accustomed to driving the 348 and 996TT, which both have majorly awesome confidence inspring brakes that could bring trains to a halt.
My mind could be playing tricks on me, not dismissing this as an explanation.
#16
How's your car coming along? Part of me is afraid to ask, but I did anyway.
#17
but you're probably uber tired...you know, being up at the asscrack of dawn this morning! ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Glad you recovered from the off-road excursion. That's never a fun thing.
--morgan
--morgan
#18
- I can go to Mosport, very fast track and never get the soft brake pedal
- on a short track close to Niagara (Dunneville), brutal for S4s, I can get a soft pedal with motul 600
- so for those that don't believe you can boil motul 600 in an S4, I have done it and the pedal goes all the wall to the floor
- the answer is you have to use the best brake fluid possible on shorter heavy braking tracks and hope it is enough - otherwise start finding things to strip out of the car to make it lighter
- I have gone through 4 sets of Pad oranges and they are fine in my opinion
- I used the crazy expensive pf-01s last year at watkins glen and I can say that I don't think I'm a good enough driver to heat then up enough and the one draw back of these pads, other than price, is that if you don't bed them in before you hit the track, you will get a horrible vibration as they don't like any foreign pad material on the rotors - I think to cook those pads you would need 335/40/17 hoosiers and you would have to stand on the brakes at every corner
- two weeks until I hit Tremblant for 2 days and learn how to drive again + I'm not going to turn down the boost (race file is 22psi across the curve) as I haven't driven the car in so long that if the turbos blow I will probably just leave the car in Quebec and walk away from this madness
