Waterford Hills PCA Driver's Education Event Write-Up.... (sorry, long)
#22
As far as going off is concerned, one of the best ways to learn the limits is to exceed them in a "safe" environment.
Scaling back is sometimes simpler and psychologically easier than pushing forward.
As others have said, sounds like you likely boiled the fluid. I've been running Motul 600 with Ferodo DS3000's and PFC01's and both setups have been nice for this K04'd 4200LB A6....
Glad to see more and more posts about your track adventures... it really is too much fun, ain't it!
#23
I'm nowhere near the limit in wet conditions, or to rephrase...I'm even further from the limit in wet conditions than I am in dry conditions.
#26
Thanks for pointing that out. As Morgan mentioned I'm operating on a major lack of sleep right now so that's my excuse and I'm sticking to it.
From Nye's link: Castrol SRF has 590F dry boiling point and 518F wet boiling point whereas Motul RBF600 has 593F dry boiling point and 420F wet boiling point.
I gess that's my cue to go to sleep, will check back in the morning.
#27
on the track you will introduce moisture to the fluid which will result in what you were experiencing today. The higher wet boiling point the better because it is able to cope with the moisture better and requires less bleeds between or before sessions. SRF outshines and outperformes every other fluid on the track but it comes at a price, ~ $75 a bottle . It is the best buck you will ever spend on the brake system.
#28
I replaced with Pagid Black and like them so far. My favorites are still the Cobalts, but they're still not available, AFAIK.
#30
how it works out for the next run at T-Hill. Thanks for the book...you REALLY must have a lot of time on your hands to log all the freakin' time and do track events and type novels about it! ;-) (alcohol talk) Oh...S8 rears=upgrade and it IS brake fade! It IS NOT THE FLUID! I get brake fade..of course it sounds like I drive harder at the track. Hence the reason why I should've possibly went with Alcons. Unfortunately $$$ IS and issue...PEACE
