Way to verify is cam tensioner is bad??? I just did one valve cover gasket and...
the chain was nice and tight between te two cams. The other however is much looser. I measured the amount the plunger is out on both (on the top only) and they are the same.
I would suppose that they are held up by oil pressure but would a loose chain be a tell tail sign of a bad tensioner?
The motor has been sitting for a little over a week. I had no seing maching noise prior to removal.
TIA
TIA
<center><img src="http://pictureposter.audiworld.com/3015/s4camchain.jpg"></center><p>
I discovered the same thing when I did mine. You are looking at the tight side of one chain and the slack side of the other. The pic explains it better than I can in words!
Dave
Dave
David Steve Perez
18
10-30-2015 01:16 PM
nobodeuno
09-06-2010 04:28 PM
Parts needed for cam seals? Getting ready to replace headcover gaskets and cam seals. When searching
Cooper993
9
12-13-2007 02:22 PM
MattKA4
11-22-2004 03:54 PM
