what, in addition to the ECS timing belt kit, is recommended for replacement during TB/WP service?
Kit comes with the following:
Timing belt
Idler roller
Tensioner Roller
Water Pump
Thermostat
Accessory drive belt
Thank you!<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnmore.html&productID=2576">ECS ultimate timing belt kit</a></li></ul>
Timing belt
Idler roller
Tensioner Roller
Water Pump
Thermostat
I did it when I did my timing belt service.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=2.7T&mod el=B5%20S4&submodel=&category=Engine">Scro ll down to OE Timing Belt Dampner</a></li></ul>
Oh yeah, dont forget coolant
:P
If havent already doing the snub mount woudl be good to do while in there.
in addition was the metal type(which I actually prefer) but it screwed up the torque settings when I put it on and I ended up shearing a bolt and stretching 2 others trying to get a consistent 10nm across the bolts. Ended up having to use the paper one and it torqued right up. Only have 20-30mi on the car so far but no leaks anywhere. Guess time will tell... other gasket had ~53K on it and was dry all the way around.
Given how many countries the audi V6s have been used in, I'm sure there are many many offbrand "central euro autozone" water pump parts/styles floating around
metal gasket. Stretched a few others too. Sat there pondering the situation for a few minutes afterward as well lol. Luckily the broken part screwed right out with the fingers(after removing the wpump). 9 new bolts from Fastenal an hour later and I was back in my s-l-o-w build process =-)
Hope you guys are well up there...
