What is the best RPM range to shift at?
Do you redline it to get the best acceleration or do you shift lower? I heard something that if you shift at like 6000rpm it's better for maximun performance....something like that....any thoughts?
For best accelleration, you want to maximize torque at the wheels. Because a higher gear reduces drive wheel torque, you should go past the torque peak before upshifting. For example, if 4th gear is 20% taller than 3rd gear you should remain in 3rd gear until the point where the torque curve (crank) has fallen 20%.
This is a longwinded way of saying "Don't forget about the mechanical advantage from a lower gear".
mys_iii
26
10-18-2001 12:00 PM
Eternal706
06-14-2001 05:05 PM
What is the best RPM to shift at in each gear? Please respond, I am always bouncing off rev limiter.
ChrisS4
10-07-2000 12:50 PM
