what is the best way to clean the threads on coilovers??(M)
I got a used set from a friend and the threads are a bit corroded. So the sleeve is a little tight and wont turn so what should i do?? TIA
RoB
RoB
No experience here, but I'd try this.
Clean off the exposed threads with a can of starting fluid and a copper bristle brush if they are full of crud.
Use penetrating oil to break loose the collar, if the threads are still crappy, use a lot of lube/tap oil and gently run the collar up and down the threads, back off and clean up the chunks and try again if it starts to bind too much.
Regenmeister
04-14-2005 12:58 PM
RidgeS4
03-29-2005 01:39 PM
mfjp
05-31-2001 06:55 AM
