what is the correct way to do THROTTLE ADAPTATION
Throttle Adaptation
For VWTOOL, (ignition ON, engine OFF!) select ENGINE, then BASIC SETTINGS, then entry 060 in the data block select window and press "accept". You can then hear the engine throttle cycle, and see the graphic display of the adaption cycle. The last value will change to "Adapt OK" when done.
zszabo
12-31-2004 09:08 AM
ed@4induktion.com
10-09-2001 05:01 PM
meem
09-02-2000 12:24 PM
