What damper setting on the Koni Coilovers?
#11
Alex responded with this...I'm assuming this is how they are set from Stasis. So you went from Tracksport to StreetSports?? I've been somewhat disappointed with mine...thinking of going to Vogtlands or PSS9's.
Front:
You will turn the damper counter clockwise while keeping constant downward
pressure on the shock shaft. You will feel it click into the adjuster and eventually it will stop turning. From this
full counter clockwise position turn the damper 1/8th of a turn clockwise.
Rear:
You will see a small adjuster wheel that you insert a small (2mm) allen wrench
into and you will spin this adjuster counter clockwise as well. You will then back it 4 sweeps clockwise.
Front:
Rear:
brat2.ua
29
10-17-2008 06:10 PM
formula1vhr
16
12-08-2006 05:14 AM
phoneyman
10-24-2005 04:05 PM
simply J
07-14-2004 06:07 AM
