what is the difference between the Quattro IV system and the Subrau's AWD?
Old 06-12-2002, 10:24 AM
  #21
Senior Member
George Burdell's Avatar
actually the WRX is very tossable... drifts easily and would generally run rings around my car.
Old 06-12-2002, 10:27 AM
  #22
Member
Nogaro's Avatar
Default Like I said.
The suspension and the power makes up for the stiff diff set up..on the STi
Actually its the other way around.
Old 06-12-2002, 10:31 AM
  #23
Senior Member
Default not as the haldex is currently programmed.. it has great potential with diff programming...
the haldex is FWD until it needs it... and even then there is a bit of leg between when it needs it and when the clutch activates and give tires the power.
Old 06-12-2002, 10:43 AM
  #24
Rob O's Avatar
Default Didn't mean to imply the Subaru system was 100/0 split ...
But the system definitely drives like a FWD under normal conditions. In snow you can really tell ... I was shocked how much it seemed to be biased to the front, driving almost like many front-drivers I've owned until the back was dispatched.
My bad on claiming it as FWD.
Old 06-12-2002, 10:44 AM
  #25
Member
CarTTman's Avatar
Default It is 100% seamless unless your dumping your clutch, but if magazine 0-60 #'s were all that
mattered, we'd all be driving WRX's. And I'm talking dry to damp pavement. Once its gets real wet, Torsen takes the cake.
Old 06-12-2002, 12:17 PM
  #26
Dan ex S4 owner's Avatar
Default Except that the auto WRX is 45/55.
They have 4 different AWD systems, depending on the model and the tranny.
Old 06-12-2002, 04:07 PM
  #27
Elder Member
Thermal's Avatar
You are correct sir. Where'd I pull 90/10 from? I've spent too much time on i-club...
quattro_silver
09-25-2003 06:32 PM
obLu
02-10-2003 07:32 AM
Max
09-23-2002 05:54 AM
Quick Reply: what is the difference between the Quattro IV system and the Subrau's AWD?
