What to do: radiator hose blew off tonite, pink fluid all over the engine compartment...from a shift
#24
It would while steam starts to build - which is 100C. But when motor continues to get hot...
unknowingly by driver, super heated steam by an engine over 150C creates so much pressure that the little hole on the radiator cap (releasing at around 1 bar pressure) cannot release enough steam pressure volume. The next weakest link is the radiator hose because of it's size in diameter and the force exerted by the pressure on that large area. The pressure is so great it moves locomotives
I've seen many blown radiator hoses with fully functional radiator caps. Most of the radiator hoses are blown because of bad head to block sealing though (head gaskets).
German cars on the other hand are very finicky when it comes to cooling. The hardest cars I've worked with making sure the system is properly bled is the VW Vanagon (rear engine, front radiator) and the water cooled Porsche's. The A4/S4 V6 engines have special bleed ports to make sure there is no air trapped in the system
Greg Burch
Audi A5 / S5 / RS 5 Coupe & Cabrio
01-19-2019 05:21 AM
audikillsbmw
9
05-05-2007 08:57 PM
BigBenny
01-13-2006 03:42 AM
