what does a snub mount do?
....it "enhances upshifting and downshifting, reduces driveline shock, and helps power transfer by taking up excess drivetrain slack."
forth, it doesn't let it rock as much..it's a floating mount attached to the front of the motor and resides within a housing located on the radiator core support..when you put it in, get it well centered in that housing...it helps if you loosen the 4 bolts to adjust the housing around it
Not that I didn't expect that...but I'm still getting used to rev matching in the S...the gear ratios are much closer than my A4, or my daily driver.
<img src="http://pictureposter.audiworld.com/31599/dsc00780.jpg">
This one is obviously the stock mount...
<img src="http://pictureposter.audiworld.com/31599/dsc00781.jpg">
This mount is our APR snub. I sat in a chair to demonstrate the strength of the materials used and had someone take the pictures.
