What else besides control arms, sway bar links, tie rods should be replaced in the suspension.
Old 12-15-2007, 09:53 PM
HIS4's Avatar
Default What else besides control arms, sway bar links, tie rods should be replaced in the suspension.
As I'm planning to do a major maintenance on my front (and maybe rear) suspension, I'm wondering what else besides a control arm kit and the coilovers themselves should be replaced as a wear item. It seems like a few people have responded to my previous posts about my suspension clunking and bottoming that my coilovers might have just reached the end of their lifespan. I know for sure that at least one of my front control arms are broken so I might as well do the whole front kit all at once. I don't know about the rear. Rear sway bar links are relatively cheap but when I inspected them they looked okay.
Is there anything else I should consider replacing since the whole suspension will come out anyway?
BTW, I'm still torn between replacing my Stasis Streetsports with Vogtland, Vogtland GTs or Eibach Pro Street S coilovers. This would be strictly for street use. It needs to use stiff enough spring rates to handle the additional 100+ lbs of audio equipment I have in the trunk.
Old 12-15-2007, 09:56 PM
Member
visintainer  [vis]'s Avatar
upper spring pirch rubber mount (front) 4D0 412 377 F
Old 12-16-2007, 04:25 AM
S4Dean's Avatar
Default How's the weather in Hawaii right now? :D I thought about doing stuff on my car but the garage was
dirty and soaked from all the ice and snow we've been tracking in from outside.
Old 12-16-2007, 05:47 AM
Cooper993's Avatar
Is this the same as the strut bushing. If not, I'd replace that too ~$25/each
Old 12-16-2007, 06:11 AM
Member
yes
Old 12-16-2007, 08:24 AM
S4_NE's Avatar
Re: upper spring pirch rubber mount (front) 4D0 412 377 F , second that
Old 12-16-2007, 09:10 AM
HIS4's Avatar
Default Cold, windy and a lot of rain.
Of course, cold by Hawaii standards means daytime temps in the mid 70s and nighttime in the low 60's
Old 12-16-2007, 11:05 PM
wilson94t's Avatar
Default Bearings, if you're getting pad knock.
I'm in a similar boat, maybe not quite sas much clunk as you.
I've noticed i'm getting more pad knock recently. I'll be doing the front bearings soon because of it. I did the rears about 15K ago.
Old 12-16-2007, 11:31 PM
Member
could you explain what pad knock is please?
Old 12-16-2007, 11:35 PM
HIS4's Avatar
2nd
VONBOTTLE
24
04-10-2011 09:50 PM
mddowlan
07-20-2007 04:01 AM
HONER
RS4 (B7 Platform) Discussion
18
07-02-2007 02:05 PM
LuvnhatemyA6
03-20-2005 07:10 AM
Quick Reply: What else besides control arms, sway bar links, tie rods should be replaced in the suspension.
