What FATS times have people seen at 3- on straight X chip before lemmi tweaks
would be different times seeing as im a tip. Track here has not been open recently, but will go out there soon
of refence for my car and setup - and to make sure that everything seems ok.
I haven't had a chance to do any real runs b/c I am dealing with my clutch.
The one pull i did (with the AC on) was a 4.9 - but I am not sure that this is a great data point to be sharing yet, would like to do a little more logging.
stage 3- with X on k04's, piggies, phenolic spacers, neuspeed g2, and a slipping clutch. I don't have a LWFW though.
Any thoughts of going with the new GIAC code or the 3- code?
I talked to Jeff Moss the other day on the 3-.
I am actually running wihtout MBC or TCD right now b/c I haven;t had the time to get it in and can't drive the car hard anyway.
I keep wavering back and forth - on one hand I like the idea of getting this running on 3- and focusing on something other than cars for a few weeks (i.e. job, wife, kids etc.) - but I am worried that the 3- code is so conservative that it will be a bit of a disapointment. I would really like to see some numbers from someone running it.
Bottom line if the 3- is faster than X with MBC and TCD i am there, otherwise I will stay X with some limited lemmi tweaks.
I would love to see some of your logs when you can get a third gear pull. I ran 5.5 FATS at Stage II. I am really not sure what I should expect to pull on K04s with stock fueling - my guess is that a 4.9 in 90 degree humid weather was not that bad.
The difference is whether or not you are the tweaking type. If you aren't, just get the 3- code with adaption channels disabled so you can "set it and forget it." However, you won't be able to use that software for a hombrew full fueling setup so just be aware of this in case you plan on going that route.
I am running stock intercoolers.
I know the time will be a little better if i wasn't worried about the clutch letting go.
Thanks for the input.
