What the hell is going on (Logs) Bad O2 and Limp Mode?
After looking at the logs I am very confused. I first thought my car was in some kind of "Limp Mode" but no CEL.
Found this when I got back home.
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Then I searched the archives and found this
"17965? Usually means actual boost is not meeting the expected (often a boost leak).
It sounds backwards, but from what I've seen, positive deviation = underboosting, negative deviation = overboosting."
Posted By DarinS4Turbo
Now I have 2 questions?
1. Is this correct does it look like I have a boost leak?
2. Do I have bad O2 sensors (4 of them)? (Both primary O2s were changed less than 1 year ago)
Conditions:
74 deg
IC temp was between 40-50 deg Celsius (104-122 F)
GIAC X only
Reset ECU and then drove around for 1 hour (~25 miles).
LOGS - Stock timing
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/2-3-115.htm">Block 2-3-115</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/2-31-115.htm">Block 2-31-115</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/3-31-115.htm">Block 3-31-115</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/20-21.htm">Block 20-211</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/20-21-2.htm">Block 20-21 #2</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/20-21-3.htm">Block 20-21 #3</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(0)/20-21-4.htm">Block 20-21 #4</a>
LOGS - +2.25 timing
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(2.25)/31-20-21.htm">Block 31-20-21</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(2.25)/31-20-21-2.htm">Block 31-20-21 #2</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(2.25)/31-20-21-3.htm">Block 31-20-21 #3</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(2.25)/115-20-21.htm">Block 115-20-21</a>
<a href="http://homepage.mac.com/edyjun1/S4/web-timing(2.25)/115-diffrent-gears.htm">Diffrent Gears 115</a>
Some times the boost goes past 5 psi but mostly it stays below. IF this is some kind of Limp Mode how come request is still high?
Bock 032 - after getting home.
<img src="http://homepage.mac.com/edyjun1/S4/32.jpg">
Thank you
Edy
1 Fault Found:
P1557 - 35-00 - -
Conditions:
74 deg
GIAC X only
LOGS - Stock timing
LOGS - +2.25 timing
Thank you
Edy
once you turn off the ignition your boost should go back to normal. However, once you get on it again it'll go back into limp as I can see from your logs. It wouldn't hurt to log 34 and 43 (EGT's) You might also want to check your n75 valve as I just worked on a car with a bad one and had the same symptoms as you.
1 Fault Found:
P1557 - 35-00 - -
only one found.
Are the O2s bad?
How do i get the Dealer to fix the O2 and N75 if they are bad.
Thank you for you response.
p.s
I will log 34 and 43 when i can.
P1557 - 35-00 - -
only one found.
Are the O2s bad?
p.s
Thank you all for helping me out. I will not be driving my S4 until I can the parts or get the dealer to fix it.
BUT do I still have bad O2 sensor(s) or not?
phoneyman
12-07-2006 10:15 AM
inliner311
10
10-29-2006 02:55 PM
Getting a 17963 SAE (P1555) Charge Pressure Upper Limit Exceeded code on a non-DBW car...(X-post B5)
audi/s/scott
Performance and Tuning
11-12-2003 08:25 PM
