what should i log for my misfires guys? logged block 32
I'd like to see if my injector duty cycle. I have logs of misfires and some of blocks 70 and 71 for my EVAP code 17884. I replaced the gas cap to no avail. i also logged 32. the first two are block 32. the third log is blocks 70 and 71 and the 4th log is misfires. i had over 60 MF on Cyl. 5 within the first 2 minutes the car was on. If anyone knows a program that the logs can be more easily read, please let me know
BLOCK 32
Wednesday,05,March,2008,23:06:36
8D0 907 551 M,,2.7l V6/5VT G 0002,
Marker,Group A:, Not Running,,,,Group B:,'032,,,,Group C:, Not Running
,,,,,,,@idle B1S1,@part B1S1,@idle B2S1,@part B2S1,,,,,
,TIME,,,,,TIME,+/-10%,+/-10%,+/-10%,+/-10%,TIME,,,,
Marker,STAMP,,,,,STAMP,%,%,%,%,STAMP,,,,
,,,,,,0.37,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,0.77,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,1.28,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,1.68,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,2.18,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,2.69,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,3.09,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,3.49,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,3.90,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,4.30,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,4.70,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,5.09,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,5.50,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,5.90,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,6.30,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,6.70,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,7.10,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,7.62,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,8.02,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,8.43,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,8.91,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,9.33,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,9.73,-3.9,2.3,-4.5,1.6,,,,,
,,,,,,10.13,-3.9,2.3,-4.5,1.6,,,,,
Block 32 again
Wednesday,05,March,2008,23:21:09
,Group A:,'032,,,,Group B:, Not Running,,,,Group C:, Not Running
,,@idle B1S1,@part B1S1,@idle B2S1,@part B2S1,,,,,,,,,,
,TIME,+/-10%,+/-10%,+/-10%,+/-10%,TIME,,,,,TIME,,,,
Marker,STAMP,%,%,%,%,STAMP,,,,,STAMP,,,,
,0.36,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,0.76,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,1.16,-3.8,2.3,-4.3,1.6,,,,,,,,,,
1,1.54,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,1.96,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,2.36,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,2.76,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,3.16,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,3.57,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,3.97,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,4.36,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,4.77,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,5.17,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,5.59,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,6.08,-3.8,2.3,-4.3,1.6,,,,,,,,,,
,6.49,-3.8,2.3,-4.3,1.6,,,,,,,,,,
EVAP
Wednesday,05,March,2008,23:37:26
,Group A:,'070,,,,Group B:,'071,,,,Group C:, Not Running
,,Purge vlv open,O2S deviation,Idle air vlv dev,Status,,Reed contact, ,Sys Status,Diag Status,,,,,
,TIME,0-93%,+/-15%,-1 to 0 g/s,TestON/OFF|OK,TIME,OPEN,Error msg,Test/check/end,TestON/OFF|OK,TIME,,,,
Marker,STAMP,%,%, g/s,,STAMP,,,,,STAMP,,,,
,0.01,37.3,-5.5,0.32,EVAP OK,0.38,Reed Closed,Abort, ,Test OFF,,,,,
,0.80,36.1,-5.5,0.32,EVAP OK,1.29,Reed Closed,Abort, ,Test OFF,,,,,
,1.69,36.5,-5.5,0.32,EVAP OK,2.09,Reed Closed,Abort, ,Test OFF,,,,,
,2.51,35.7,-5.5,0.32,EVAP OK,3.00,Reed Closed,Abort, ,Test OFF,,,,,
,3.42,34.9,-5.5,0.32,EVAP OK,3.80,Reed Closed,Abort, ,Test OFF,,,,,
,4.22,35.7,-5.5,0.32,EVAP OK,4.62,Reed Closed,Abort, ,Test OFF,,,,,
,5.13,36.9,-5.5,0.32,EVAP OK,5.53,Reed Closed,Abort, ,Test OFF,,,,,
,5.93,35.7,-5.5,0.32,EVAP OK,6.33,Reed Closed,Abort, ,Test OFF,,,,,
,6.73,36.9,-5.5,0.32,EVAP OK,7.13,Reed Closed,Abort, ,Test OFF,,,,,
,7.65,37.3,-5.5,0.32,EVAP OK,8.14,Reed Closed,Abort, ,Test OFF,,,,,
,8.54,36.9,-5.5,0.32,EVAP OK,8.94,Reed Closed,Abort, ,Test OFF,,,,,
,9.34,36.1,-5.5,0.32,EVAP OK,9.74,Reed Closed,Abort, ,Test OFF,,,,,
,10.14,36.5,-5.5,0.32,EVAP OK,10.54,Reed Closed,Abort, ,Test OFF,,,,,
,10.96,36.1,-5.5,0.32,EVAP OK,11.47,Reed Closed,Abort, ,Test OFF,,,,,
,11.87,36.5,-5.5,0.32,EVAP OK,12.27,Reed Closed,Abort, ,Test OFF,,,,,
,12.76,35.7,-5.5,0.32,EVAP OK,13.16,Reed Closed,Abort, ,Test OFF,,,,,
,13.58,35.3,-5.5,0.32,EVAP OK,14.07,Reed Closed,Abort, ,Test OFF,,,,,
,14.48,37.3,-5.5,0.32,EVAP OK,14.88,Reed Closed,Abort, ,Test OFF,,,,,
,15.28,36.9,-5.5,0.32,EVAP OK,15.69,Reed Closed,Abort, ,Test OFF,,,,,
,16.17,35.7,-5.5,0.32,EVAP OK,16.59,Reed Closed,Abort, ,Test OFF,,,,,
,16.99,36.1,-5.5,0.32,EVAP OK,17.39,Reed Closed,Abort, ,Test OFF,,,,,
,17.79,36.1,-5.5,0.32,EVAP OK,18.19,Reed Closed,Abort, ,Test OFF,,,,,
,18.60,34.9,-5.5,0.32,EVAP OK,19.00,Reed Closed,Abort, ,Test OFF,,,,,
,19.40,35.7,-5.5,0.32,EVAP OK,19.80,Reed Closed,Abort, ,Test OFF,,,,,
,20.22,36.1,-5.5,0.32,EVAP OK,20.62,Reed Closed,Abort, ,Test OFF,,,,,
,21.11,36.5,-5.5,0.32,EVAP OK,21.51,Reed Closed,Abort, ,Test OFF,,,,,
,21.91,36.5,-5.5,0.32,EVAP OK,22.32,Reed Closed,Abort, ,Test OFF,,,,,
,22.81,36.9,-5.5,0.32,EVAP OK,23.21,Reed Closed,Abort, ,Test OFF,,,,,
,23.63,36.1,-5.5,0.32,EVAP OK,24.14,Reed Closed,Abort, ,Test OFF,,,,,
,24.52,36.9,-5.5,0.32,EVAP OK,24.94,Reed Closed,Abort, ,Test OFF,,,,,
,25.43,36.5,-5.5,0.32,EVAP OK,25.85,Reed Closed,Abort, ,Test OFF,,,,,
,26.35,36.5,-5.5,0.32,EVAP OK,26.75,Reed Closed,Abort, ,Test OFF,,,,,
,27.26,35.7,-5.5,0.32,EVAP OK,27.66,Reed Closed,Abort, ,Test OFF,,,,,
,28.15,35.7,-5.5,0.32,EVAP OK,28.55,Reed Closed,Abort, ,Test OFF,,,,,
,29.05,35.7,-5.5,0.32,EVAP OK,29.45,Reed Closed,Abort, ,Test OFF,,,,,
,29.87,35.3,-5.5,0.32,EVAP OK,30.27,Reed Closed,Abort, ,Test OFF,,,,,
,30.67,36.1,-5.5,0.32,EVAP OK,31.07,Reed Closed,Abort, ,Test OFF,,,,,
,31.48,35.3,-5.5,0.32,EVAP OK,31.98,Reed Closed,Abort, ,Test OFF,,,,,
,32.38,36.1,-5.5,0.32,EVAP OK,32.89,Reed Closed,Abort, ,Test OFF,,,,,
,33.29,36.1,-5.5,0.32,EVAP OK,33.69,Reed Closed,Abort, ,Test OFF,,,,,
,34.18,35.3,-5.5,0.32,EVAP OK,34.58,Reed Closed,Abort, ,Test OFF,,,,,
,35.00,36.5,-5.5,0.32,EVAP OK,35.39,Reed Closed,Abort, ,Test OFF,,,,,
,35.90,35.7,-5.5,0.32,EVAP OK,36.30,Reed Closed,Abort, ,Test OFF,,,,,
,36.70,34.9,-5.5,0.32,EVAP OK,37.11,Reed Closed,Abort, ,Test OFF,,,,,
,37.59,34.9,-5.5,0.32,EVAP OK,38.01,Reed Closed,Abort, ,Test OFF,,,,,
,38.41,36.1,-5.5,0.32,EVAP OK,38.82,Reed Closed,Abort, ,Test OFF,,,,,
,39.32,34.9,-5.5,0.32,EVAP OK,39.82,Reed Closed,Abort, ,Test OFF,,,,,
,40.23,36.9,-5.5,0.32,EVAP OK,40.63,Reed Closed,Abort, ,Test OFF,,,,,
,41.13,36.1,-5.5,0.32,EVAP OK,41.53,Reed Closed,Abort, ,Test OFF,,,,,
,41.93,37.3,-5.5,0.32,EVAP OK,42.34,Reed Closed,Abort, ,Test OFF,,,,,
,42.74,37.3,-5.5,0.32,EVAP OK,43.15,Reed Closed,Abort, ,Test OFF,,,,,
1,43.65,36.1,-5.5,0.32,EVAP OK,44.04,Reed Closed,Abort, ,Test OFF,,,,,
,44.46,32.2,-5.5,0.32,EVAP OK,44.95,Reed Closed,Abort, ,Test OFF,,,,,
,45.35,0.0,-5.5,0.32,EVAP OK,45.75,Reed Closed,Abort, ,Test OFF,,,,,
,46.15,0.0,-5.5,0.32,EVAP OK,46.55,Reed Closed,Abort, ,Test OFF,,,,,
,46.97,0.0,-5.5,0.32,EVAP OK,47.37,Reed Closed,Abort, ,Test OFF,,,,,
,47.77,0.0,-5.5,0.32,EVAP OK,48.17,Reed Closed,Abort, ,Test OFF,,,,,
,49.58,0.0,-5.5,0.32,EVAP OK,50.07,Reed Closed,Abort, ,Test OFF,,,,,
,50.47,0.0,-5.5,0.32,EVAP OK,50.89,Reed Closed,Abort, ,Test OFF,,,,,
and finally misfires
Wednesday,05,March,2008,23:27:08
,Group A:,'015,,,,Group B:,'016,,,,Group C:, Not Running
,,Cyl 1,Cyl 2,Cyl 3,Misfire status,,Cyl 4,Cyl 5,Cyl 6,Misfire status,,,,,
,TIME,0-5,0-5,0-5,activated,TIME,0-5,0-5,0-5,activated,TIME,,,,
Marker,STAMP,,,,,STAMP,,,,,STAMP,,,,
,0.40,0,0,0,Enabled,0.01,1,0,0,Enabled,,,,,
,1.31,0,0,0,Enabled,0.81,1,0,0,Enabled,,,,,
,2.11,0,0,0,Enabled,1.69,1,0,0,Enabled,,,,,
,3.12,0,0,0,Enabled,2.62,2,0,0,Enabled,,,,,
,3.92,0,0,0,Enabled,3.52,2,0,0,Enabled,,,,,
,4.83,0,0,0,Enabled,4.41,2,0,0,Enabled,,,,,
,5.74,0,0,0,Enabled,5.23,3,0,0,Enabled,,,,,
,6.64,0,0,0,Enabled,6.24,3,0,0,Enabled,,,,,
,7.44,0,0,0,Enabled,7.04,3,0,0,Enabled,,,,,
,8.35,0,0,0,Enabled,7.85,4,0,0,Enabled,,,,,
,9.15,0,0,0,Enabled,8.75,4,0,0,Enabled,,,,,
,9.95,0,0,0,Enabled,9.55,4,0,0,Enabled,,,,,
,10.75,0,0,0,Enabled,10.36,4,0,0,Enabled,,,,,
,11.56,0,0,0,Enabled,11.15,5,0,0,Enabled,,,,,
,12.48,0,0,0,Enabled,12.08,5,1,0,Enabled,,,,,
,13.28,0,0,0,Enabled,12.88,5,1,0,Enabled,,,,,
,14.08,0,0,0,Enabled,13.68,5,1,0,Enabled,,,,,
,15.08,0,0,0,Enabled,14.57,5,1,0,Enabled,,,,,
,15.88,0,0,0,Enabled,15.48,5,1,0,Enabled,,,,,
,16.78,0,0,0,Enabled,16.38,5,1,0,Enabled,,,,,
,17.69,0,0,0,Enabled,17.20,5,2,0,Enabled,,,,,
,18.51,0,0,0,Enabled,18.11,5,2,0,Enabled,,,,,
,19.42,0,0,0,Enabled,19.00,5,2,0,Enabled,,,,,
,20.31,0,0,0,Enabled,19.92,5,2,1,Enabled,,,,,
,21.11,0,0,0,Enabled,20.71,5,2,1,Enabled,,,,,
,22.01,0,0,0,Enabled,21.53,5,2,1,Enabled,,,,,
,22.83,0,0,0,Enabled,22.41,6,2,1,Enabled,,,,,
,23.72,0,0,0,Enabled,23.32,6,3,1,Enabled,,,,,
,24.63,0,0,0,Enabled,24.14,6,3,1,Enabled,,,,,
,25.45,0,0,0,Enabled,25.05,6,3,1,Enabled,,,,,
,26.35,0,0,0,Enabled,25.95,6,3,1,Enabled,,,,,
,27.16,0,0,0,Enabled,26.75,6,4,1,Enabled,,,,,
,27.96,0,0,0,Enabled,27.56,6,4,1,Enabled,,,,,
,28.76,0,0,0,Enabled,28.36,6,4,1,Enabled,,,,,
,29.66,0,0,0,Enabled,29.16,6,4,1,Enabled,,,,,
,30.47,0,0,0,Enabled,30.06,6,4,1,Enabled,,,,,
,31.37,0,0,0,Enabled,30.87,6,4,1,Enabled,,,,,
,32.19,0,0,0,Enabled,31.77,6,4,2,Enabled,,,,,
,33.08,0,0,0,Enabled,32.69,6,4,2,Enabled,,,,,
,33.90,0,0,0,Enabled,33.50,7,4,2,Enabled,,,,,
,34.79,0,0,0,Enabled,34.30,7,4,2,Enabled,,,,,
,35.59,0,0,0,Enabled,35.19,8,4,2,Enabled,,,,,
,36.51,0,0,0,Enabled,36.01,8,4,2,Enabled,,,,,
,37.42,0,0,0,Enabled,37.00,9,4,2,Enabled,,,,,
,38.31,0,0,0,Enabled,37.91,9,4,2,Enabled,,,,,
,39.11,0,0,0,Enabled,38.71,9,4,2,Enabled,,,,,
,39.93,0,0,0,Enabled,39.51,9,4,2,Enabled,,,,,
,40.73,0,0,0,Enabled,40.33,9,4,2,Enabled,,,,,
,41.54,0,0,0,Enabled,41.13,10,4,2,Enabled,,,,,
,42.42,0,0,0,Enabled,42.04,10,4,2,Enabled,,,,,
,43.24,0,0,0,Enabled,42.84,10,4,2,Enabled,,,,,
,44.14,0,0,0,Enabled,43.64,10,4,2,Enabled,,,,,
,44.95,0,0,0,Enabled,44.53,10,4,2,Enabled,,,,,
,45.77,0,0,0,Enabled,45.35,10,5,2,Enabled,,,,,
,46.66,0,0,0,Enabled,46.17,10,5,2,Enabled,,,,,
,47.46,0,0,0,Enabled,47.06,10,5,2,Enabled,,,,,
,48.38,0,0,0,Enabled,47.88,10,6,2,Enabled,,,,,
,49.18,0,0,0,Enabled,48.78,10,6,3,Enabled,,,,,
,49.98,0,0,0,Enabled,49.58,10,6,3,Enabled,,,,,
,50.79,0,0,0,Enabled,50.37,10,6,3,Enabled,,,,,
,51.59,0,0,0,Enabled,51.19,10,6,3,Enabled,,,,,
,52.58,0,0,0,Enabled,52.10,10,6,3,Enabled,,,,,
BLOCK 32
Block 32 again
EVAP
Shaun
11
03-07-2008 05:12 AM
TighTT
04-13-2004 04:07 PM
