What size tire should I run on a 17x8.5 SSR Comp wheel with..
stock suspension?
I currently have 225/45 on them but am thinking of going to a 245/40.
My current tires are Kumho MX's but the new tires will be P Zero Nero M&S.
Thanks.
Thanks.
225/45R17 if you want your speedo to read right, or you could try 235/40R17 since your at stock
height, but your speedo might read a little off. It really depends on what tire you get, since they all seem to be different widths. I just got some BFG KDW2's and they are wider than most, so 225/45R17 was the best size for me.
Based on my calculations..
A 235/45 is 1.4% taller than stock height.
A 245/40 is 1.03% shorter than stock height.
I figured the 245/40 would have less Speedo variation as well as giving a small (probably not noticeable) gearing advantage.
I was just concerned with the width aspect possibly causing some rubbing issues of the 245 on the car.
spt@lubzu
01-26-2006 05:58 PM
M.S.G. Homey
Wheels & Tires Discussion
04-05-2002 07:21 PM
s4rocket
9
12-20-2001 02:32 PM
dingster
10
03-19-2001 03:57 PM
