What size tires will fit on a 18x8.5 set of wheels with 30mm offset? (m)
I just bought a new set of wheels for the spring. They are 18x8.5 with 30mm offset. What size tires will fit with the stock suspension? I was thinking 235/40-18 but i'm not sure....
That's not really the best offset for that size of wheel, especially for this car.
The widest tire you can get under an S4 is a 255, and only a small number of people are running that size. I'm running 255/35/18's on 18 x 8.5 Fikse FM/5's with an offset of 40.5mm front, and 38.65mm rear. With this wide of a tire, and being lowered a little, I had to roll the front fenders really well to prevent rubbing.
With a 30mm offset, 225's or 235's is probably the widest tire you can use, those wheels will be sticking out pretty far.
will 8.5in wide wheels rub? if not, what offset is ideal to set as flush to the fenders as possible?
bla4ck
10-20-2005 10:46 PM
YosemyTT
23
04-11-2005 08:39 PM
