What spring pressure should i get when ordering External tial wastegates?
What size waste gate are you running?
What engine size, how many gates?
What is the lowest boost setting that you can have? ( 1.2 bar spring, means you wont have anything less than 1.2 bar 19 psi or so. )
what turbo and AR?
The more details you have, the better i can help you choose the right gate.
what turbo and AR?
-3.0L
-2.8L heads with 2.8L cams
-gt2860rs's with tial stainless exhaust housings .64 A/R
-2 tial MV-S wastegates (I believe 38mm?)
Spring pressure:???
Planning to run around 26psi
goal: 600awhp on 93 octane
Spring pressure:???
to open the wastegates?
I'm just trying to understand how this works and how the spring pressure is relevant to the application
Based on that and your overall goals, you will be set with a 1 bar spring. You will need to run more boost than 26 PSI to achieve 600 whp. you will have to roughly move about 79 lbs min.. and on a 3.0L it either means spinning it to ths stars, or ~ 28 psi.
Let me know when you need to order the TiAL Turbos and gates. The MVs is a 38mm Valve, V-band.
<img src="http://gallery.avivascience.com/main.php?g2_view=core.DownloadItem&g2_itemId=490&g 2_serialNumber=2">
<img src="http://gallery.avivascience.com/main.php?g2_view=core.DownloadItem&g2_itemId=493&g 2_serialNumber=2">
send me an email, there are many was to configure those turbos.
dpattanas
09-24-2003 04:21 AM
ivansis
01-18-2002 12:18 PM
