What would cause excessive tread wear on only one tire?
My right front tire has a LOT less tread than the left front. At first I thought alignment was to blame, but wouldn't both tires be affected? Both are Bridgestone Potenza RE 040. Any input is appreciated.
You mean left turns...
...my front right always wears the fastest too. Generally on the street for aggressive drivers there will be more tire wear in the aggregate on left corners than right corners. U-turns are left corners and left corners at intersections are longer in length than right corners, so you spend a greater number of miles over time turning left than turning right.
No, I meant right turns...
As in a right turn would load the opposite side and cause more tire wear there...in this case, on the left side tire.
Anyway, it's a stretch. I've never had issues with one front tire wearing significantly different than the other, so I'm just throwing out possibilities.
Joe_M
10
09-06-2013 09:33 AM
Zoomer
12-18-2002 12:58 PM
Heavy TT
08-22-2000 08:03 AM
