what would cause requested boost to be lower than actual boost?
It's homebrew and ECUx shows that requested boost spikes to 1.3 bar and tapers down to 0.9 bar. Actual boost is flat at 1 bar. However, my defi HUD shows spike at 1.45 and holding at 1.35 until redline.
The other question since I see differences in ECU and in-cabin boost display, how accurate are these electronic HUDs?
However, why would my requested boost appear so much lower on ECUx than what I see on the gauge?
to run more boost (what you see on the gauge), we run a TCD that shows the 1bar flat actual boost curve.
Basically, what you're seeing is exactly what pretty much every other homebrew person on the planet sees....requested from the ECU, actual from the ECU, and actual on your boost gauge are all different. ;-)
may be it is tip chip? how about unplug your ecu for like 30~40mins then plug it in and do logs again!
just un hooking your battery for a few seconds? what exactly does unplugging the ecu do? just reset everything its learned so you can start fresh or what?
