What would the HP have to be on the S4 if it were a N/A car?.....
AudiWorld Expert
To keep the same numbers of course .. 0 to 60, the 3650 pounds of fat, all wheel drive, and quarter-mile. And if possible, keep it a 6 cylinder in this hypothetical equation.
For curiosity because of the fact that the S4 looks bad on paper but is definitely not bad. Thanks.
TL type S circa 2001-2 have decent peak power (think around 260hp) and ran mid to high 6's in the 0-60, while nissan engiens of similar peak hp ran flat 6's or high 5's (240hp maxima ran high 5.9 in a mag)...those cars are all a tiny bit lighter than an S i think....
so i'd say, for a relatively torquey(good midrange, peak torque not all teh way up top) NA V6...305+hp.
drag calculators will give you a better estimate.
If he wants to move a 3600 lb. S4 with a normally aspirated V6, I'm going to say something along the lines of 280hp-287hp/270-273 lb-ft 3.5L V6 in the G35/350Z would work fine.
power our cars and achieve the same performance numbers we have. Me and my friend who has a track Z are pretty even performance wise. So if you add hundreds of pounds and all-wheel drive to that, i dont think it will be enough
FWIW, the G35 coupe is only about as fast as a 330 (though the Z is faster than a stock S4)...it only loses 7 hp to teh Z and is a little heavier....
so i'd say that you'd need at least 300hp, given teh S4's extra heft over the G35 coupe and AWD drivetrain loss (i'm sure AWD hurts a little in teh 1/4 and helps in the 0-60)
The extra HP/TQ is compensating for the ample plateau of torque/hp the OE turbo provides. The gearing has to keep the more potent motor in it's power peak. The hp/torque peak will depend on valve lift/timing and displacement.
If everything were kept the same on a 2.8L, it'd have to be a 4.5l or so to make the above numbers. Add some compression, more aggressive cam, timing and rev limit, it could be done with 4.0 with little problem.
YMMV!!
YMMV!!
NoMoreBMWs
Audi A5 / S5 / RS5 (B9)
31
06-22-2018 01:24 PM
DrGP
32
01-08-2006 10:39 AM
Pleasanton 335
13
01-27-2004 04:26 PM
mm
18
01-19-2004 04:14 PM
Jim Will
13
10-25-2000 12:45 PM
