What's the difference between H&R Streets and Ultras? Spring rates, ride height, harshness....
I want to eliminate a great deal of body roll and dive-n-squat, but don't want the ride to be unbearable.
I may, on occasion, track the car, but the vast majority of the driving will just be spirited street driving. Will the Streets be ok, or should I go w/ Ultras? Or, should I look at something else, too?
Thanks.
Thanks.
Ultra's run higher spring rates, not sure if the shocks are the same...
I'm partial to Stasis Track Sport Coilovers.
You can choose any spring rate you want, but I think I'd recommend 600/700 for what you are looking to do with your car.
I think H&R Streets are like $1800, Ultra's are like $2k...
was that your question?
My biggest push of the Stasis coilovers over the H&R's is the serious amount of shock work that Stasis has done (you should see the plot of the shock, they can show you it, cuase they've done extensive testing using a shock dyno).
IMO, for the extra couple hundred, you are getting a far superior shock. After all, springs are springs...
I disagree, but in all reality, spring rates are completely subjective as to what is to high or low
I've been running 600/700 for 9months now, and although I go to the track as often as possible, this is still my street car, so daily drivability is what's most important.
I'm actually increasing my spring rate since I was surprised as to how streetable 600/700 has been.
But like I said, to each his own...
S4 in Margaritaville
15
04-08-2004 03:11 PM
s4power
01-17-2003 10:08 AM
