Whats the difference between a K04 and K24? also will k24s bolt up to the S4?
#13
everyone talks about the hybrids and putting the bigger wheel in the k04 housings but what if you did the hole k24 turbo? with a little custom piping and hardware?
#20
you can't pick out turbos like you pick tomatos in a supermarket.
and i hope you have a tuner in mind before you even get started.. unless you have access to me7.1 source code.<ul><li><a href="http://andywhittaker.com/ECU/BoschMotronicME71/tabid/68/Default.aspx">something NOBODY here has even talked about, except minhea</a></li></ul>
