What's the thoughts on removing pre-cats on factory DP's verse AWE Dp's. What about tossing codes?
No codes if you relocate the O2 sensor...
Gutting your stock ones will probably net you 90% of the performance of an aftermarket DP setup. The other 10% being larger piping.
Only thing needed to be done to relocate the O<sub>2</sub> sensor aft the main cat. Unless you can get a hold of a stock set of stock DPs to modify, expect more downtime as you would have to remove your DPs then get them modified then put them back on.
my2000apb MEGABOOST
02-02-2008 11:02 PM
~DonQPremiumTequila~
02-09-2006 07:30 AM
Milpitas2.7T
10-08-2002 09:19 PM
alleuroS
04-01-2002 05:08 PM
