Wheel spacer side effects
I am thinking of adding some 10 mm wheel spacers to my stock wheels for winter use. (I dont like the way the wheels sit so far in with no spacer.)
I've done a search, but didn't really see any side effects of using the spacers. Does anyone know of any? Is there any reason I shouldn't use them?
It will increase the loads on the wheel bearings and hubs. The Audi already has issues with wheel bearings. I've also seen lug nuts fail. These failures can all be catastrophic.
I personally wouldn't do it unless you had no choice.
Oh, and it also adds unsprung weight.
Having said that, 10mm isn't a lot.
Stephen
Stephen
shorten the life of your wheel bearings and change the loading on some suspension components. there have been some discussions in the past about it in the past. scrub radius and steering angle inclination are effected.
applied on the hub with an aftermarket wheel. that said, i don't think 10mm spacers or a 10mm change in offset is that bad. it does change the scrub radius which effects the steering feel however (not sure for more or less).
