Wheel spacers... only for looks, or has any performance benefits?
Re: Wheel spacers... only for looks, or has any performance benefits?
Primarily for looks and/or getting some aftermarket wheel/tire combo to clear everything. Adding a spacer will have the same effect as a wheel with less-positive/more-negative offset, and will increase wheel bearing loads. Ideally, you want a combination of wheel size/offset that maintains the same effective offset as the factory set-up--the same relationship between the centerline of the wheel and its mounting surface on the hub.
SUBLIME
9
03-02-2006 12:08 PM
