When my k03s go bad, should i replace with k04?
If i replace my stage II tip with k04, would i have to install new plumbing for air, and would i have to get a different chip? What are the least amount of upgrades to successfully run k04s? (stage III- tip?) would i have to upgrade my tip trans?
put the K04s in there (you'll need inlets too). Put a MBC in parallel with your N75
to bring boost down.
Or you can get a 3- specific tune with 5-bar FPR for a little more power.
Either should be fine for your tip
I don't think K04s alone would increase power any.
I'm running K04s with a Giac stg 1 chip without any problems. I don't have a MBC either. Bare minimum to do it is the inlet pipes. I know there is a place that makes them for 300 or so bucks. Maybe 034 motorsports?
