When running a MBC with GIAC X, is there a limit to how low I can set boost?
Running on the track, I'd like to run with less than 15lbs boost. Will I get throttle cut if I set it that low? Any other problems? Should'a never sold that stock ecu!!
MBC won't affect that, but SEL scaling will. Adjusting SEL scaling is easier than twisting the **** on your MBC.
If people can get away with a .95-1bar TCD on X, they most definitely can actually turn boost down that far without any codes/limpness. Still, boost near or at redline is much more important to lower if you are going to the track. SEL scaling all the way, baby.
I used to cut throttle on occasion at ~6,000 RPM with this setup:
<img src="http://pictureposter.audiworld.com/69223/block_115-mbc_only-57d.jpg">
As you can see, the overboost isn'e even quite 200mbar.
Set it, log a 3rd gear pull to redline, adjust accordingly. Otherwise, just pick a random # (80% for instance) and go with it. If you are MBC in parallel, no need to even adjust the MBC for the new boost setting because the ECU will follow the lowest setting between the 2 (MBC and N75) at a given RPM.
scaling would throw codes, and not the MBC. Glad I asked before buying!
just for ***** n' giggles.
His MBC was set well over 1 bar. Because he was in parallel and requested boost was lower than the MBC setting, the N75 took over and he was making less than .6 bar ;-)
<img src="http://img.photobucket.com/albums/v654/DocSlow/LOG-01-115-AMS_Stage_5_56_SEL.gif" alt="Image hosted by Photobucket.com">
