Where does one apply a door seal lubricant (gummi pfledge) to stop the creaking durring frame flex?
Is it on the front end of the rubber lining (located on the car) or on the back end of the same rubber lining, where it makes contact with the metal door frame?
If it is the later do you think a strip of felt stuck to the metal frame where it makes contact with the rubber would be a permanent solution?
Thanks!
Thanks!
hahah I haven't gotten my clutch in yet... I'm PRAYING that it comes in by Friday. but also...
I found out that when my clutch was replaced by DUB****S, they didn't put the top 2 bolts on my transmission housing back... so I'm trying to get them through Brian@avalon
you prob don't need those, just use a zip tie or whatever. I was also thinking
We don't really need to reatach those hard to get halfshalfts... all wheel drive is nice but you don't really need it, matter of fact you don't even need both your turbos really...
I seem to get quite a bit of wind noise from my drivers-side door, especially in (duh) windy weather
RMN
12-01-2006 10:40 AM
KaMaKaZieP -ALUMIN8-
Audi 100 / A6 (C4 Platform)
01-15-2002 09:15 PM
