While replacing the cam chain tensioner seals, is there anything else that I should have done as a
preventative / maintenance measure?
I'm also having a problem starting the car when the engine is warm. I've ruled out the coolant temp. sensor (replaced it twice already).
Someone suggested it might be the cam position sensor. I'm not sure if that's right, but should I just get that replaced anyway?
Also VAGed the car today and found that the right front oxygen sensor is busted. Could that be the cause of this problem?
TIA.
TIA.
